Old 1st January 2012, 10:37 PM
MoysieWRX's Avatar
MoysieWRX MoysieWRX is offline
Default MX5 Donor
Have a 1.6 Mazda MX5 Import (eunos roadster) as a donor (92-93 K Reg).
Hoping to start my build soon following saturns guide, once i gather my steel.
Does anyone have electronic copies of workshop manuals/ technical info etc on the mx5/eunos that i could maybe get a copy?
Someone i know thinks that this car would have a LSD. Could anyone clarrify or dismiss that this is a possibilty? Could you tell by looking at the diff if it is a LSD?
Can anyone recomend a good forum/website for Mazda MX5 info and Engine tuning?
Regards
Last edited by MoysieWRX : 1st January 2012 at 10:58 PM. Reason: Added year of car
Old 1st January 2012, 11:10 PM
Big Vern Big Vern is offline
Originally Posted by MoysieWRX View Post
Have a 1.6 Mazda MX5 Import (eunos roadster) as a donor.
Regards
1.6l MX-5 great basis for the haynes roadster
Ebay is a good source for copies of the Mazda workshop manual - plenty of general info on the net (flyin' miata, solomiata, targa miata) etc.
As for the LSD (that old chestnut) don't assume that because it's an import it has an LSD! Lots of so called experts at your local boozer will tell you the japspec cars all have LSD's their WRONG! and I've found out the hard way
Pre 93 VLSD only on V spec - 93-94 1.8 may have torsen 1 and 94 on 1.6 and 1.8 may have torsen 2. Only surefire way to check is to take driveshaft stubs out of diff and peer inside (if you can see gears it's NOT an LSD!)
Good luckwith the build BV
Old 1st January 2012, 11:27 PM
MoysieWRX's Avatar
The MX5 is a great car, be even better as a Haynes roadster.
It is also quite hard in places to get a sierra as a donor. Around my area, the majority of sierra's are all bought up by the stock car racers.
Would also be good to use BMW's as there are always a good stock around my area but would need to spend alot more time to ensure everything is done correctly.
Will Sticking with the MX5 for the first build as there is the saturn guide to follow. Maybe take on the challenge once my firs build is complete.
As for the DIff will have to have a peek and see as you said.
Just bought the haynes manual off of Ebay.
Old 2nd January 2012, 11:08 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
I have a workshop manual you can borrow till I need it pm your details and I will send it to you
Old 2nd January 2012, 11:26 PM
MoysieWRX's Avatar
Thanks that's a very kind offer VMAX but just bought a haynes workshop manual off ebay last night
Thanks anyway
Im sure it will be worth the small amount it costs, when stripping the car and when it comes to messing around tuning the engine etc.
"There are no secrets to success. It is the result of preparation, hard work, and learning from failure."
"The road to success is always under construction"
Michael
Photo Albums
Donor: 1.6 Jap import MX-5
Chassis: Based upon Saturn MX-5 guide
Official start date: TBC
Build cost to date: £400 profit from donor sales
Old 2nd January 2012, 11:40 PM
If you search on google there is a RAC version which is specific to the 1.6 mk1 which is much easier to use. You can pick it up on Amazon quite cheaply.
Old 3rd January 2012, 07:42 PM
MoysieWRX's Avatar
Thanks, will wait and see how i get on with the haynes manual first.
May not need it anyway, its just handy to have one there just incase you get stuck with something.
Usually buy one for every project, dont end up using it that much.
Although none of the other projects resulted in complete stripdown.
Michael
Photo Albums
Old 3rd January 2012, 09:20 PM
trainer trainer is offline
the vlsd on the mx5 has different stub shafts than the open
lots of info here
http://www.miata.net/garage/diffguide/index.html
the vlsd was available on all cars as an option in japan most were fitted with it iv had 3 all had vlsd my current has torsen type 2 of a 97s
Old 3rd January 2012, 10:46 PM
MoysieWRX's Avatar
lots of info here
Thanks mate, loads of good info on the link.
Performance wise, which is the best diff to have the torsen or VLSD? Is there a noticable difference between them?
Michael
Photo Albums
Old 5th January 2012, 11:17 PM
the torsen diffs are much stronger(300bhp+) and more active but still a road diff the vlsd is ok if it still works only lasts 30k if used hard and won't take more than 200bhp
they come in 3 different ratios 4.30:1 this is standard 1.6 and vlsd also the very rare torsen from a 99 sport with a 5 speed gearbox
And 4.10:1 ratio for 1.8 cars and all other torsens no vlsd
And 3.909 for the 6 speed gearbox
the six speed ratio is a no no you will go know where unless you get a 6 speed box its the same size
so its between the others 4.30:1 will give the best acceleration
however most of the turbo cars go for the longer ratio of the 4.10:1
maybe in a lighter car the longer ratio ie the 1.8 diff with the 1.6 engine
you can buy or source other sized ring and pinions that fit the diff from other mazdas!
i would go for the 1.8 torsen you will need the prop and drive shafts also
they come at a cost i paid £400 pounds for mine complete with shafts and uprights
or stick with what you got until you break it didn't take me long to break my vlsd
