Whats the general consensus?
I was thinking either injecting something like waxoyl into the chassis once finished. Or expanding foam? Or is it worth bothering? I was thinking to avoid any rattles etc from inside the chassis. What do the likes of caterham/westfield etc do? Im maybe overthinking, but its a sat night and im stuck in! lol cheers,
Stew |
I dont think expanding foam will do anything.
Try something like this; http://www.supercheapauto.com.au/onl...56#Description |
I doubt if there is anything rattling about in the RHS you will be able to hear it anyway ...pretty loud these cars
Been mentioned before and opinion is that there is very little rust on the inside of the welded tubes as there is no ingress of moisture,a squirt of waxoil or wd40 would not go a miss in the open ends.
Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice. |
Just saw this in my hotrod magazine!
http://www.facebook.com/photo.php?fb...7&l=f7d01629af |
there was this stuff called ziebart
seen it on an old mk1 fiesta and a alfasud both spotless in the rust deparment was like a black waxoil not sure if you can still get it but cars i have seen spoke for themselfs alfasuds where known for rusting im going for some form of wax injection on mine |
They all look like good ideas but the only way you can be sertain you cover everthing is by galvanising?
My Blog: deannoshaynesroadster.wordpress.com (under construction) Being overtaken is a sign of weakness. South Wales Kit Car Club www.southwaleskitcarclub.co.uk WWW.HELPFORHEROES.ORG.UK XBox Gamer tag: D34NNO |
Think you will find Ziebart died along with plugs,points and condensers,used to use it on new cars in the 70's.
Filled the box section chassis of my Land Rover with old engine oil----seemed like good idea til it needed some welding
most of them cars can only be swept off a workshop floor now ![]() |
| Thread Tools | |
| Display Modes | |
