Old 15th January 2012, 06:16 PM
Default First start!
Yaaay, it's alive!
http://www.youtube.com/watch?v=0IcigzxlGjg
The ECU, apparently, shuts off after 2 seconds of running. I'm guessing one of the essential sensors is not working. I'll try to hook up to the diagnostic slot next.
Old 15th January 2012, 06:26 PM
Rig the fule pump to run constantly and see if it runs for longer. It may not be comming on after the initial prime.
Old 15th January 2012, 06:29 PM
I have rigged all the wires directly to the battery, including the pump. Not a very safe setup, come to think of it.
Old 15th January 2012, 06:33 PM
Smile Well done
Great news Albert
Re: The ECU cutting out.
Do you think it may be be possible that the the fuel relay is not cutting the fuel pump back in once the reserve pressure in the fuel rail has been used up ?!
Just a thought lurking about in my mind.
Congratulations on the first start of your engine, good times
Old 15th January 2012, 06:35 PM
Awwww man
Me way too slow
Looks as if you were thinking along the same lines as me TT
Old 15th January 2012, 07:06 PM
LOL..
It will probably need a STAR type reader to get the codes.
Old 15th January 2012, 07:10 PM
But "sounds" like the fuel pressure is insufficient to me.. and I had not listend to the video the firsts time!
You could try adding a few squirts of easy start into the intake to try and keep it running.
Old 20th January 2012, 02:42 PM
TT, you were absolutely right! Initially I had just a drop of old fuel in a jerrycan. When I topped it up a few days later, the fuel pump buzzed but didn't build up pressure. I disconnected the pump outlet to help it prime. It started circulating. When I reconnected the hoses, after a few attempts the engine started up and ran until I stopped it!
Old 20th January 2012, 04:23 PM
Here's one more vid, with my elaborate set up :
http://youtu.be/NhH5Gg7M5Lg
Old 20th January 2012, 05:07 PM
Andy J Andy J is offline
I like the flames
AJ'S Build
