Old 15th January 2012, 07:07 PM
Wgroove Wgroove is offline
Default How to connect a Ford Zetec 2.0 crank sensor ?
Hi everybody,
I'm preparing everything to connect my zetec to my Emerald ECU.
I'm having some doubts bout connecting the crank sensor.
The diagram from the Emerald says:
Sensor + Crank sensor or digital distributor input signal
Sensor - Earth return for main/cam trigger sensors
How can i find out wich is + and - on my sensor ?
Many Thanks !
Old 15th January 2012, 07:56 PM
cant answer your question full (sorry) but it depends if it a hall type or inductive. they produce different patterns , now i stand corrected on this but if im thinking correct inductive wouldnt matter as its an alternating scope pattern.
you dont by any chance have an occiloscope do you ?
Mike
Old 16th January 2012, 02:22 PM
from memory no 1 is +ve look hard at the connector and you will see they are marked 1 and 2. it wont do any harm if you put them the wrong way round so don't worry too much.
Old 16th January 2012, 07:30 PM
ha ha this is one i always find funny as the pickup is simply a magnet with a thin copper wire around it as the the teeth pass it it chops the magnetic flux and induces a sharp ac wave/voltage in the copper wire.
the idea is to get the ecu phased to the engine.
if the wires are switched it offsets the phasing as the up peak would be down.
here is some pic's of a ford one as iirc there all the same
Old 16th January 2012, 07:34 PM
those megasquirt lads are a lifesaver! im glad you posted that link it reminded me that theres a few things i needed to check out
Old 16th January 2012, 07:45 PM
oh and cam and abs picups work the same and wires must be screened as at low rpms voltage is low and we can get lots of interferance from almost anything that gives off rf (coils,ht's,relays,alternators and so on)
Many thanks !
Thats was the answer I needed
Now I can connect my wiring correctly.
Regards,
Wim
