Old 22nd January 2012, 08:52 PM
Gear Monkey Gear Monkey is offline
Default Gear Monkey's Build Blog
Today myself and Kitch took our 1st steps to building our Roadsters by cutting out all the 90 degree cut sections of the 25x25mm and 25x50mm, so not a great deal done but a job done well nonetheless.
http://flic.kr/p/bgXitF
Fortunately we have at our disposal lots of space and as we're both engineers we just about have between us have all the tools to do a really nice job.
http://www.flickr.com/photos/66567276@N05/6744105961/
All cuts made to within a 0.10" (0.25mm) and perfectly square
http://www.flickr.com/photos/66567276@N05/6744105443/
I also practiced making the front frame uprights that require a 26 degree notch removing and then bending to form the correct angle. I made 2 13 degree cuts using the disc saw in the picture (awesome bit of kit) and it worked perfectly on an off cut so far easier than expected.
http://www.flickr.com/photos/66567276@N05/6744106635
All in all a good few hours work. If all goes to plan by the end of February we'll have two professional standard chassis ready and waiting to be fitted out.
Updates and pictures to follow soon
Old 22nd January 2012, 10:08 PM
I dont know you look a bit short of space there, only joking good luck with the build and keep the photos coming
Old 22nd January 2012, 11:15 PM
Yeah It's a little cramped but we'll do are best
Old 29th January 2012, 08:02 PM
We had a good few hours on Saturday so cracked on with cutting out our chassis members. The main chassis is all all cut with exception of the triangulation, tranny tunnel and rear end so getting there slowly!!
http://flic.kr/p/bkuTBM
http://flic.kr/p/bkuTrv
Old 5th February 2012, 06:02 PM
Quick update...Despite the sub zero conditions myself and Kitch spent Saturday working on the chassis and have managed to get very close to cutting up all the steel complete with angles and bends. One more day cutting and then we'll weld the lot up into two chassis.
http://flic.kr/p/bp3ncn
Still on track to have it on wheels by Summer!
Paul
Old 5th February 2012, 06:21 PM
Thumbs up
Cracking start,
Nice ideas for your build on the rear end in your drawings. It's fun to play around with the original design and come up with something unique to your own build.
Good luck with the rest of the build...johno
Old 5th February 2012, 08:42 PM
will_08 will_08 is offline
Looking good guys, a super start.
Keep it up!
Old 9th February 2012, 12:01 PM
Thanks Guys I appreciate your comments
I've spent a few more hours measuring, cutting and deburing so here's the latest pics. Sorry they're not a little more interesting.
http://flic.kr/p/bqXtsK
http://flic.kr/p/bqXtwv
Paul
Old 9th February 2012, 12:12 PM
andysredmini andysredmini is offline
Don't forget to allow for the distortion caused by welding the bend / notch on the front frame uprights.
I found through trial and error they pulled in by about 1.5deg when i welded mine. I welded some samples in different orders e.g inside first then sides, or sides first then end, to try and prevent it but in the end just opened them up a bit before welding.
Regards
Andy
Old 9th February 2012, 11:29 PM
Thanks for the info Andy
