Old 31st January 2012, 02:48 PM
mitch d mitch d is offline
Default zetec wiring
right i no theres alot out there about wiring up the zetec i have a 1.8 silvertop EEC-IV ecu out of an 1998 escort gti i have most of the loom and im thinking of stripping the loom down to the bear essentials i have key and transponer i have the pin out diagram for it but wondering if any1 no's whats needed and wots not!.im not using the injection as bike carbs will b fitted. any help would b appreciated.
Old 6th February 2012, 10:12 PM
if you are running carbs then you need somthing like megajolt unit to run your ign with the edis unit and ditch the ecu and all the rest of its junk as it will not work.
Old 7th February 2012, 07:43 AM
EEC-IV???
Had then not swapped to EEC-V?
