Old 3rd February 2012, 11:07 AM
kitcarkid kitcarkid is offline
Default wide chassis?
hi has anyone made a wide chassis? i was thinking about it for more room in the interior, what car do you get longer drive shafts off?
please post pics if you have done a wide chassis and how much u have done it by it would be really helpful thanks
Old 3rd February 2012, 03:27 PM
This keeps coming up so I'll have a go .... you can either make the tunnel narrower or make the chassis wider. You dont need a 125mm wide tunnel for a prop shaft 50mm wide, I've done this and most hatch back sized seats will fit. If money is a concern and you make the chassis wider you could use lobro bolt on shafts and add spacers between the CV joints and the flanges on the diff end. Another way round it is you use near 0 off set rims but they can be pricey.
You also have to consider that there is no standard body work that will fit the back end so you'll have to make that as well.
Old 3rd February 2012, 04:17 PM
carlknight1982's Avatar
How much wider do you want it im 19 stone and a 44 inch waist yes its a little tight but i have no problems getting in, its more my seats that are tight not the chassis.
Carl
Roadster No 2 build
Cost to Date : £93
Old 3rd February 2012, 06:57 PM
shh120m's Avatar
shh120m shh120m is offline
Carl
and the rest
