Old 5th February 2012, 06:53 PM
Jimmyd Jimmyd is offline
Default Fuel pump mounting
Hi,
I'm using a Facet solid state type fuel pump, question is should I using bobbin type mounts or just bolt down?
J
Old 5th February 2012, 09:15 PM
Probably best to use some sort of rubber mounting to absorb the vibrations and protect the pump.
Old 5th February 2012, 09:47 PM
Totally agree it will drive you mad with the amount of noise even from the rear.
Old 6th February 2012, 01:40 AM
Yes you definitely have to use rubber mounts. That is why Facet pumps also come as a kit with extra filter, fittings and rubber mounts. Rubber mounts are also available separately. See FPA905 last page of this document :
http://www.fuelsystem.co.uk/web-facet.pdf
Hope this help.
Sylvain
Old 6th February 2012, 06:05 PM
pritty much any fuel pump needs a rubber mount its a noise thing
Old 6th February 2012, 09:16 PM
Thanks Gents. Mounts now ordered!!!
J
