Old 22nd February 2012, 08:31 AM
brainbug007's Avatar
Default Glueing Edge Trim to GRP
I've reached the stage where I want to glue some rubber u channel trim onto my bonnet and wings. I've got some no more nails stuff knocking about and was wondering if that stuff would be up to the job. If not can anyone suggest a good cheapish alternative?
Old 22nd February 2012, 08:57 AM
MarkB MarkB is offline
Most contact adhesives will do it as long as the surface isn't shiney, you will need to "kill" the wax in the gel coat whatever you use anyway.
Old 22nd February 2012, 12:52 PM
so how do i "kill" the wax in the gel coat? is it as simple as just sanding the area down 1st?
Old 22nd February 2012, 04:19 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
I would use some simple panel wipes the type you would use before painting a car
Old 22nd February 2012, 04:20 PM
Wynand's Avatar
Wynand Wynand is offline
What he meant is to get rid of the smooth glossy surface of the gelcoat - #180 grit wet dry should do or preferably aluminum oxide sanding strips (I use Abramat brand) which you use dry.
BTW, laminating resins are waxed but gelcoats are unwaxed and needed to be shielded from oxygen to be able to cure - hence used in a female mold and laminated over.
Flowcoat (covercoat) on the inside of moldings, IOW over the laminates are also waxed to be able to cure...
Contact glue should do the trick or use SikaFlex 292 (expensive way)
Wynand
http://5psi.net
Old 23rd February 2012, 12:45 PM
I use this stuff (Goop) for most everything.
http://www.biosafe-inc.com/ag_adhesives.htm
Old 24th February 2012, 09:12 AM
To "kill" the wax sand both the gel and matt faces then wipe with minimal amount of acetone...It only sticks when you don't want it to
