Old 4th March 2012, 09:36 PM
cirrusjock cirrusjock is offline
Default BMW based roadster
Hi
So I have been looking for an MX5 to use as a donor. I do however have an old 3 series 2.0 BMW sat on my drive that I was going to put on ebay next week. Its mechanically sound but the paintwork has laquer peel and a few dents so could be the perfect donor.
Are the many BMW based roadsters being built? Does anyone have any links to build diarys for BMW based cars?
It is an automatic so would also need to convert it to manual. I do like a challenge though.
Old 5th March 2012, 10:32 AM
TQ_uk TQ_uk is offline
Not Haynes builds but BMW based so may be of interest for ideas...
http://www.farouxsportscars.com/roadster-mb1/
http://www.gkdsportscars.com/
Old 5th March 2012, 10:47 AM
No reason at all why you couldnt build a Haynes using Sierra or MX5 donor but use the BMW engine, gearbox, induction and wiring loom.
You would then be on familiar territory for most of the build and would just need to do some mods for the engine and gearbox mountings.
Alternatively you could get a bellhousing adaptor to marry the BMW engine to a Ford type 9 gearbox.
Old 5th March 2012, 11:02 AM
rally205 rally205 is offline
There is a guy on this forum building a BMW based roadster using all of the running gear. He lives near me in Rugby but I cannot remember his username. I will try and find him for you.
Old 5th March 2012, 12:31 PM
I've seen this chassis at Delting show last year and it is 100% Haynes chassis with BMW E36 running gear.
Old 5th March 2012, 01:49 PM
Thanks guys,
I am going to start by stripping the BMW and storing what I may need and putting the rest on ebay. I figured the car is probably worth more as bit than it is as a complete car anyway.
Meanwhile I will draw up the book chassis in inventor and then try and get the BMW parts in inventor somehow. This will give me something to play with.
Oh, and I am also trying to learn to mig weld so I could be busy.
Old 5th March 2012, 05:32 PM
i think the gkd would be well worth a look.
i dont know of any 100% bmw doner locost plans of the self build verity only kits
would be an ideal choice as plenty about and cheap with parts availble.
Old 6th March 2012, 11:32 AM
The Faroux? I was examining it at Delting also...
The design may be the same but pretty sure its bigger all round, i.e wheel base, width
Old 9th March 2012, 11:15 AM
The guy from rugby that is building one is Graeme Webb and his username is
the same.
Old 13th March 2012, 10:25 PM
ftaffy ftaffy is offline
Posted a few time on locost uk on this topic.
I am building a complete BMW E36 3 series clubby.
Currently finishing off the chassis, though its a custom design (same width (1118), same frame height (355) as roadster and slightly longer (3137 v 3083)). In hind sight i should have just modded the Haynes chassis to suit the BMW that way the design would be useful for others as well.
The issues you will face:
The front upright - Cant be used on a double a-arm without some mods. ie GKD welded on change (not ok in australia), modded strut (what i am doing see below) or use another one.
Rear upright - Bin it and use the Haynes style but you will need to get a bearing carrier made to bolt on. Nothing major required justed a backing plate with a tube to hold the bearing.
Engine - VERY tall! The sump hangs down and there only a few options. Dry sump (~$1000 by the time you have it installed IMO), cut the sump down by ~1in throught middle (AL so bit of extra welding fun) or just raise the engine + use a bulge.
Steering column, the lower section is AL, so you will need to get an early 5 or 7 series lower steel section that be extended as per the book mods.
Seat belts- The coupe rear seats are mounted in the seats so get a pair of Sedan rears instead.
I have a build diary located here:http://www.ozclubbies.com.au/index.p...ys-tf7i-build/
You will need to register, then get approved to access the forum.
Any questions let me know, dont have any 100% drawings as i did alot of on the fly updates while building.
Also i am Melbourne, Australia.
Cheers,
Taffy
