Old 5th March 2012, 09:11 PM
Talking ZX9R Install Details (For Loony)
Sump has been chopped and plug relocated, also theres a baffle plate, plenty of ground clearance the car goes over speed humps with no problems at all :
Old 5th March 2012, 09:17 PM
Pic showing ground clearance :
Origonally had this air filter setup:
Dont bother with this, even with the correct jetting all the top end power is lost. I have now gone to the airbox set up, from 8000 rpm the car now pulls like a train and sounds better too
Old 5th March 2012, 09:22 PM
Been playing with some 3M di noc as well, very expensive but the finish is excellent :
Next up is to get a decent exhaust manifold made as the primary lengths and bores are all wrong, then it should be making 150 bhp +.
If theres anything else you want to know, give me a shout
ATB Dan
Old 6th March 2012, 09:10 PM
loony's Avatar
loony loony is offline
First thing - I love your car Looking great and must be fun to drive.
Your posts will be very helpful. I'll ask few questions, but in right time.
Now - I'm glad I took OEM airbox from previous engine owner Maybe I'll later build my own GRP airbox, but for now it's OK like that.
Bigger problem is exhaust manifold - I have OEM, but I don't think it's stainless - rather alu/titanium (knowledge from locostbuilders ) - so welding will be difficult.
I'm preparing my DIY sprocket adapter, so next thing is... propshaft.
Do you use TRT or standard prophaft ?
Unfortunately I'll use cheaper version so "standard" propshaft made from two Sierra propshafts... with hope for later upgrade and electric reverse (with laser cut reverse gear)
Thank you for help with my "strange" build (in poland BEC's aren't popular).
Lucas
ZX9R BEC Haynes Roadster - build cost so far: £1125
My build thread
"Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe
