Old 10th March 2012, 06:07 PM
Eternal Eternal is offline
Default Nosecone Advice.
Hello all.
Started work on getting the nosecone to fit today. It fits quite well now so thats great. The next task is to work out how to split the air into two sections one for intercooler one for radiator. So far you will see what i have done below. Think this looks ok and different enough from the MNR nose.
On another note there is quite a large gap between the wishbone bolts and cone will this be a problem? I really dont want to have to mess around with that as well!
Skyline Roadster
Old 10th March 2012, 06:09 PM
Skyline Roadster
Old 11th March 2012, 08:16 AM
MarkB MarkB is offline
The sides will be the easy bit after all the work needed to level off the nose, you can fill the gap between the nose and chassis by making the side panels that much longer and include a fixing point so it attaches securely to the nose.
Take your time and faff, it will be a better end result.
