Old 1st April 2012, 07:24 PM
excavator81 excavator81 is offline
Default chassis paint or powdercoat
hi all builders just wondering what would be the best solution to finish the chassis
PAINT:what type is hammerite up to it????
:2k / celly / truck paint
POWDERCOAT: if i need to weld after for some reason will it wreck it
are there any other ways of finishing your chassis info much needed as im unsure what is best for my chassis
kind regards Dan the Digger
Old 1st April 2012, 08:28 PM
i sprayed mine with epoxy mastic 121 from rust.co.uk the car has been on the road for 2 years now an there is not a spot of rust on it to date so far. i have chipped it a couple of times with tools etc but it touches up nicely with a bit of halfords satin black and doesn't show.
Old 2nd April 2012, 06:34 AM
Wynand's Avatar
Wynand Wynand is offline
I painted mine with an epoxy twin pack paint over lead oxide primer. Can weld to chassis and easy to just reapply primer and paint at these areas again which I have done with mine a couple of times when changes are made.
Except for being expensive, with powder coating you are stuffed if the chassis was not prepared (shotblasted) correctly, PC tends to "peel" off when damaged - seen this on someones chassis recently. And you cannot weld on the chassis later again...
Wynand
http://5psi.net
Old 4th April 2012, 08:42 AM
i found chassis black over isopon zinc 182 primer works real well as the primer has etch qualitys and chassis black is pritty chip resistent (i have bashed my chassis about a fair bit in my build)
2l of each will be plenty if your spraying and use celulose thinner
cheap and easy to use
2k need air feed masks btw as it has isocynate in it you dont want that in your lungs or on your skin!
