Old 2nd April 2012, 10:51 AM
MikeB MikeB is offline
Default CVH Cooling Pipes
The metal pipe that bolts to the front of the engine direct fromt the waterpump.
It goes backwards then does a 90 bend then pretty much staight.
Its currently too long to get a 90 bend on it to redirect it to the front of the car.
What have other people done. Cut it down (but the diameter opens up towards teh end and it has a smaller bore take off so I'd loose that to) or cut the end off, chop a bit out the middle then weld the end back on again.
Or bend it round?
Old 2nd April 2012, 03:12 PM
I have the same engine too,
Before my engine swap ( like for like engine ) my original water pipe elbow that you are describing I left alone, but I agree it made it for a very tight turn for a rubber hose......but it DID work ok, albeit a bit of a snug fit up against the GRP side panel.
When I bought the "new" engine from forum member Gus, i noticed that he had shortened the said elbow by approx 2 inches, so I used that one & it does seem to work really well.
I,d suggest cutting & rewelding it, not sure if it would kink if you tried to bend it
edit.....it looks like Gus had chopped a bit out of the middle so that he didn,t lose the smaller bore end ( hope that makes sense )
hth
Old 2nd April 2012, 03:15 PM
Thanks. chop a bit out of the middle I will!
Old 2nd April 2012, 04:01 PM
Could someone measure for me how high their radiator sits above the top of the front frame.
Need to mount mine but no nosecone as yet.
M
Old 2nd April 2012, 04:11 PM
I,m not at home to measure the rad position, but maybe these pics will be helpful.
Its a polo rad
Old 2nd April 2012, 06:32 PM
I cut a90 bend out of an old rubber top hose to turn the bend towards the rad then had to fit an ali reducer to join to the smaller dia Polo bottom hose. Hope that makes sense---it works too--the wet stuff goes round and round and squirts into the header tank
Old 2nd April 2012, 10:48 PM
gus's Avatar
gus gus is offline
Hope this helps
Gus
Old 3rd April 2012, 11:49 AM
Thanks all I'll give the cut and shut a go!
Old 11th April 2012, 02:29 PM
Completed the cut and shut on the pipe
Did another classic and weldling the pipe 180 deg the wrong way round, really nice welds aswell, anyhow have left it as is as sticking up the small bore pipe would have been close to touching the exhaust, it now exits down so it will be a little bit more of a pain to route it but it will be clear of the exhaust.
ANyone know where this pipe goes to, I'm assuming the thermo housing so when shut it just bypass the radiator through this pipe?
Old 11th April 2012, 02:55 PM
brainbug007's Avatar
I suppose you could set it up that way but I think the norm is to have the bottom outlet from the radiator going in and then the pipe from the thermostat going to the top of the radiator. I then just put a couple of T junction in the pipe from the bottom radiator hole for the expansion bottle etc.
