			 Hi all
	I am using r1 bike carbs with the r1 fuel pump BUT what do i do with the pinto fuel pump di i block it off and if so how would the best way to do that  |
	If you need a friend, call me, if u need company call me, if you need help call me, if u need money this number is no longer available.  |
			 many thanks 1 on its way now should i put a gasket  on it as well
			 A standard fuel pump gasket, yes
	There is a little drive pin actuated by a cam on the auxiliary shaft, remove that after removing the fuel pump and before putting the blanking plate on  |
| Thread Tools | |
| Display Modes | |
