			 is it possible to join a throttle cable as all i need to lengthen is about 6"
			 If its for bike carbs, just use a bicycle brake cable, not worth the hassle trying to join two cables together.
	ATH Dan  |
			 I took apart the Mondeo cable I got with my engine, used the bits the cable sheath inserts into (the tensioning system pedal side and the square mount at the throttle).  For the cable, I used one I had (a Civic rear hatch release cable with one end rusted off).
	Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate.  |
			 when there is stuff like this http://www.ebay.co.uk/itm/Universal-...item43ac92f692  its not worth messing with.
	When The Results Disagree With The Theory: Believe The Results And Invent A New Theory If I had two brains I,d still be a halfwit The cave http://s1116.photobucket.com/user/my...deshow/mancave The build http://www.haynes.co.uk/forums/showthread.php?t=12669  |
			 many many thanks to all went today and got a bike cable with all the fittings and hope to fit tomorrow
| Thread Tools | |
| Display Modes | |
