Old 9th April 2012, 01:40 AM
nickharding nickharding is offline
Default New Member. DIY Chassis Build - Help
Hi Guys.
I have just joined the forum and still getting used to the layout.
I'm about to start a Haynes Roadster build, and it will accommodate a Limited slip diff (as the book) but will be driven from a Hayabusa turbo lump.
I have been recommended here from another forum to try and find some information.
I will never have a car engine in it, so was told maybe I should consider making the tunnel narrower so that you have more foot-well space?
Thoughts?
I downloaded a copy of "Build your own sports car on a budget" and it was released in Feb 2007. A member on the other forum recommended I under took the amendments on this forum, link..
http://www.haynes.co.uk/forums/showthread.php?t=2430
Would just like peoples thoughts and opinions on this build and the advice i have received.
Does anyone happen to have plans for a narrower tunnel chassis build? This would be perfect and right up my street.
At the moment I have it in my head i need to build the book chassis but with the amendments?
Cheers.
Nick.
