Old 9th April 2012, 04:22 PM
waynes world's Avatar
waynes world waynes world is offline
Default Let the fun begin :) (newbie)
Just a quick hello form me, just joined as i have been mooching for a few days and just ordered my copy of the book, should be here this week i hope.
I am a member on the other forum but as i believe i need to use the Haynes chassis for my build i found this forum with the adcive form others, so best of both worlds for help when needed i hope
I have almost given up my old hobby of 4x4 off roading, i want some thing a bit cleaner that welding rust together and scraping mud off everything, i have had the Locost build book in my shed for 16 years now and never got around to doing anything untill now, i still have my new 4x4 off roader but that mite just be for sale soon, only to fund a bit more of this project, we will see.
I have a small work area i will be doing the chassis work in, very small but i will squeze in i think. i have just cleared it out and built a new work bench and shelves to go in next before i make the work bench for the chassis. I have a good area for when the chassis is built to get around easyer. I will be gettting a marque for that.
My plan is to get the book and build the chassis ny the book but leavae a few parts out for fitting the 4x4 set i want, i will be using sierra 4x4 running gear ( complete donor ) but the engine will be the 2.9i 24v Cosworth engine and MT75 G box. There be the reason for leaving bits of the chassis build out, i know there will be loss of space for the driver with the T box where it is, shame i cant bet a left hand drive T box LOL. I will see if i can widen it a bit more so it will be wider on the central part of the chassis, i was going to use a Locost but i found the Haynes is wider.
I will be building the chasis while i am either hunting down parts or saving for the donor, either way i like to do build threads and as soon as i get the steel in i will strat the thread, i know folk like pics of builds, also you can tell me what i have done wrong easyer
All the best folks
Wolly
Old 9th April 2012, 04:34 PM
Hi Wayne and welcome .That sounds like a real blaster if you can keep it stuck to the road
You'll get lots of help and advice here anyway
Old 9th April 2012, 05:00 PM
Thanks kida, the reason i am trying a 4x4, and i love 4x4 anyway
Old 9th April 2012, 05:45 PM
Hi and welcome Wayne.....should be interesting watching a 4X4 develop ....go for it bud.
Old 9th April 2012, 05:50 PM
Welcome to the forum Wayne, I,m sure you,ll find lots of help & info on here
There was a 4x4 Haynes Roadster build in progress a while ago, tho its all gone quiet so not sure if its still being built,
I supplied the chassis kit, I,ll try & find a link to the thread for you.
All the best for your build .
Old 9th April 2012, 06:01 PM
Thanks for the welcome lads
That would be good Andy if you could, cheers
I am looking all the time for parts etc etc, i am not sure now if to get a donor or parts as i go, can come by some good bargains at times, sure i can get some hubs and other bits to make up.
Already lookig at wheels LOL
wolly
Old 9th April 2012, 06:44 PM
Davey's Avatar
Davey Davey is offline
Hiya Wayne, what happened to your plan to build a motorhome? (fellow motorhomefun.co.uk member here
To be fair I seriously doubt a 4X4 is do-able simply because the trans tunnel will not accomodate the transfer box and the forward axle prop shaft would be between the drivers legs. I vaguely recall someone else planning to do a 4X4 using Mondaneo running gear but haven't seen anything of it for a year or more.
I'm building a bastardised version of the Haynes but based on Locust chassis (polite words for piece of crap) spaceframed using the Haynes design as guidance and using a BOA Cosworth V6.
D.
Old 9th April 2012, 07:36 PM
Could have been Leon from Liverpool possibly......
Old 9th April 2012, 07:55 PM
Hi Davey, the camper is sort of on the back burner, i found my Ron Champion book in the shed LOL, still have the UMM though kida
Since i got the book, yes some time ago, i always wanted to do a 4x4, heck if i cant, i tried If Dax can do it....yes i n,ow but i can try
I thin k the main problem is the T box, but the chassis must be easy to mob to fit it, even build my own, i am new to chassis building so the reason to use a wider chassis as the Haynes.
flyerncle, you lost me kida with this
Old 10th April 2012, 08:52 AM
Here's the 4x4 Mondeo thread:
http://www.haynes.co.uk/forums/showt...ghlight=mondeo
It all went a bit quiet though...
