Old 10th April 2012, 05:36 PM
Eternal Eternal is offline
Default Painting time is a week away! Need some advice on my options.
Hell all!
Well im about 1 week away from painting the chassis.
Only thing i THINK i have left to do is weld on the steel floor (i have two sheets 2m x 1m sheets @ 2mm and 2.5mm over kill i know!) and install 4 brackets for brake lines. Once thats done i can start the prep work.
I have read loads and loads about the paint and there seems to be way too many options. I would like to know what you guys have done. I'm looking for a paint that i can start final rebuild quite soon and cant really wait around days and days for it to full set hard so a fast setting paint would be fantastic. I have access to a gravity fed spray gun so can use that along side rollers and bush. Also to note is the floor will be painted so must not be a flakey paint.
All help and advice welcome as i need to order the paint soon if its a specialist item.
Thanks!
Alex
Skyline Roadster
