Old 18th April 2012, 04:39 PM
misty misty is offline
Default throttle cable
HI all
How do we get the correct length of the throttle cable, i thought it was correct and now i find the nipple needs to be shorter than i had getting a bit peed off with the cable
any easy ways of doing it?
Old 19th April 2012, 10:51 AM
MikeB MikeB is offline
cut it down and put a solderless nipple on it?
Old 19th April 2012, 11:13 AM
I would use a solderless one to establish the length first then use a solder on one after as much stronger I think personally.
Old 19th April 2012, 01:40 PM
i will just do that first class many thanks
