Old 25th April 2012, 09:50 PM
mgglep's Avatar
mgglep mgglep is offline
Default roll bar
Hi there everyone i have Just had a spare minute to upload some more to my flickr account photos i have just finished my roll bar here are some pictures
http://www.flickr.com/photos/6760569...in/photostream
My Build pics
Old 25th April 2012, 09:54 PM
That looks very smart indeed
are you using 2 bolts to fix it to the bottom chassis rail ( at bottom of the back stays ) as I can,t quite see from the pics ?
Nice work , & the other pics look good of the car too
Old 25th April 2012, 10:04 PM
mgglep's Avatar
Default fixings
yes i read others where having problems so i used the normal 4 x 8mm fixings at each side at the top i have used 2 x 10mm fixings at each side at the bottom i ran the harness bosses through so i could weld top and bottom it is also fully tig welded (i am not take any chances lol)
My Build pics
Old 26th April 2012, 10:08 PM
martin62 martin62 is offline
Default roll bar
Where did you get the roll bar from.Thanks Aidan
Old 26th April 2012, 10:57 PM
mgglep's Avatar
Default rollbar
Hi there
I made the bar myself i had to lend a friends CNC pipe bender to roll the 50mm hoop luckily i saved the programme on the bender so he can knock them out as he wishes. without sounding arrogant i spent the time and the radius on the corner is spot on no kinks or ripples. if anyone is interested i could probably get you in contact with him i am sure he could knock some more out fairly cheaply
The rest is just 38 tube the bosses are tapped to 7/16 unf as per harness bolts or eyes.
Oh yeah the tube is all the correct type wall thickness etc
My Build pics
Old 26th April 2012, 11:12 PM
Default roll bar
Do you know roughly how much he would charge for the hoop and bars.Aidan
Old 26th April 2012, 11:35 PM
mgglep's Avatar
Smile Bar
I will give him a ring tomorrow and get a price
My Build pics
Old 27th April 2012, 06:54 PM
Thumbs up roll bar
No problem
