Old 27th April 2012, 12:24 PM
Default Harness mount positions
Just a quick one !
Can anyone see a problem with the top harness mounts being on the cabin side of the rear roll bar ? I have bought some westfield harnesses that are snap fittings on the top and bolt in at the bottom but to get the best position for routing them around the seats means the eyebolt will be in / close to the main hoop pointing to the front of the car on the outer shoulder straps ?
Old 29th April 2012, 02:57 PM
mr iva will look at them as a projection i think.
Old 30th April 2012, 08:58 PM
Originally Posted by monsterob View Post
Just a quick one !
I have the same type of harness mounts but mine are Willan,s,
I realise that my seats are not the same as per your fitment position but I,ve fitted the Hooped "eyelets" for the upper harness mount & covered them in trim ( securely ) & used a small split pin to stop the snap fitting from being opened,
here,s 2 photos, MAYBE they are helpful ?
Old 1st May 2012, 09:53 AM
Mmm bit of a problem there then ! My seats are f/glass i could cut some holes in the to allow the harness to pass through the seat itself ? Any probs there?
Old 2nd May 2012, 10:32 AM
You don't have to put the harnesses through the seats, they can just go around.
Old 2nd May 2012, 08:08 PM
It would be easier to go through the seat as i could locate them in the same manner as andy.
Do yours bolt all the way through andy into another thread ? I was just planning the nut welded onto the top of the crossbrace with a hole in the bar. Captive. Ut as it were ?
Old 3rd May 2012, 07:30 AM
snapper snapper is offline
The tube should be threaded all the way through and the seat eye bolt long enough to go the length of the tube
Old 3rd May 2012, 11:21 AM
rally205 rally205 is offline
Why can't the harness simply be looped around the crossbrace like in a rally car? Surely if it is good enough for the MSA and FIA it is good enough for IVA.
Old 3rd May 2012, 11:49 AM
Does it state they have to pass all the way through in the manual or simply state they have to be secure ? The nut would be part of the crossbrace and the threads would be in safety and the lower brackets work in the same way ?
Old 3rd May 2012, 11:54 AM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Without checking I would imagine the problem with looping the harness round the crossbrace is that in my old race car I looped the harness round the strut brace on my rollcage and although this was fine for racing I did find there was a problem with latteral slip of the shoulder straps but in racing the harness is tightened up a lot more than in a road car so in the road car the harness could slip in the an accident
Just my thoughts hope it helps
