Old 30th April 2012, 10:37 PM
nickharding nickharding is offline
Default Chassis nut and bolt list?
Does anyone happen to have a chassis and suspension nut and bolt list for the haynes roadster build using a sierra as a donor car? .. My father can bring home any spec nut or bolt and any length, but only has this access for another month or so before another company take the business over and lock the access down to the stores. So if anyone happens to have a spec list for the chassis that would be fantastic!
Any help would be great!
Cheers.
Old 1st May 2012, 12:24 AM
rpjg1975 rpjg1975 is offline
This is a copy of the list given for the last group buy that was organised. Hope it helps?
2 x M12 X 260mm Bolts - (Rear Uprights)
2 x M12 X 220mm Bolts - (Diff Mounts) <--- I have increased the length of these by 20mm from the previous group buys as the bolts I got were not long enough for my diff (standard sierra).
20 x M12 X 70mm Bolts - (Wishbones, Rear Camber Adjuster, Lower Shock Mounts)
6 x M12 X 60MM Bolts - (Upper Rear and Front Shock Mounts)
30 x M12 Nyloc Nuts - (Type P - these are a bit thicker than normal nuts and better suited to suspension applications)
30 x M12 Plain Full Nuts - (these are for test fitting components without ruining the Nyloc nuts)
60 x M12 Flat Washers - (Form A)
60 x M12 Black Plastic Nut Covers.
Russ
Old 1st May 2012, 02:18 PM
Brilliant. Cheers mate.
Old 1st May 2012, 10:27 PM
you will need at least 4x 7/16 unf nuts for your seat belt mounts (weld on)
a stack of m12 washers
8x m8 nuts for roll bar mounts (weld on)
some m12 studding and nuts is handy to do your suspension mounts
