Old 2nd May 2012, 11:04 AM
MikeB MikeB is offline
Default CVH Coolant Temp Sensor.
Having nearlly completed my radiator and coolant pipe fit (see my build thread) I've realised I don't have a water temp sensor anywhere in the system.
The radiator has the hole for the radiator fan sensor there is the same dimension hole in the CVH thermo housing (I assume this was for the same rad fan switch in the fiesta CVH install it was originaly from).
So it would be great if I could get a temp sensor to fit the threads in the CVH thermo housing, but the sender I have are a smaller thread.
Can you get them in the larger thread size, or any other tips on where to put the sender?
