			 OK I'm ordering Gaz shocks from rallydesign and there web ordering site is missing the section I need so I got a catalogue today.
	![]() Which has me completely confused. The image shows shocks without springs and three different types. So I assume you have to order springs separate, and do so on ebay. I then spot at the bottom about when ordering to spec spring. I do some checking and find that they come with bloody springs in the price.   So am now trying to get money back for springs ordered.Anyhow I know I want 14' - 9.5' shocks all round but which ones, bearing or bushed? I think I now understand I want bush meaning a bush in the top hole not a bearing but whats with the other image of the big shock, that one isn't even in the table below is it?? Anyway could someone please tell me if... 140/095 B12 is the correct one as I've already made one cockup and don't want to do so again!? Thanks ![]()  |
			![]() See what I mean! b'stards trying to confuse my easily confused mind. ![]()  |
			 Chris,
			Dont order just yet, as the mx5 uses slighty different shock/spring legnth to the book spec, especially on the rear , but i cant remember off the top of my head, il double check and post it up as soon as i get to work in the morning
	A few build photos... www.photobucket.com/ntsengineering  |
			 OK thanks Nathan. Not ordering till Thursday.
			 Try Damper Tech, thats where I got mine as they might be cheaper (worth a call).
			 It's more simple than you think relay
	  You pick the open/closed length then the style of eyelet needed then its up to you what body/spring dia you go for then pick spring dia, length, weight. A std sierra based car only needs 14-9.5" bush ended shocks You need to select springs to suit your build relay  |
			 OK confused again. What model of coil overs are correct? GP, GS, GHA??
	http://www.dampertech.co.uk/gazcatalogue.pdf  |
			 Give them a ring, say your building a Haynes roadster an he will sell you the correct ones. Just say what rate shocks you want.
	No faffing with models ect.  |
			 140/095B12 in std or gold will be fine for a sierra based roadster
			 OK just to end this thread for anyone looking in the future. An mx-5 Saturn/NTS build requires....
	Front 350-400lb 8" length 1.9" ID springs. I got some on ebay in black from JJC for about £50 inc vat the pair. Shocks can be either 13" open 8" closed with a 1 inch extension to the shock or as I have bought 14" open 9.5" closed I got mine from rallydesgin for £60 inc Vat each. Rear 200-250lb 7" length 1.9" ID springs. Again I got some on ebay in black from demontweaks for around £50 a pair. Shocks as advised by Nathan, should be 12" open 9" closed. I got Gaz again from rallydesign 12" open 8.5" closed. If you order from rallydesign you want to order. Universal bush eye top and bottom. 2x 140/095/B12 2x 120/085/B12 So the whole lot cost about £340-350 delivered inc a c-spanner for adjustment. If you don't mind yellow springs you can knock £35 off that price getting your springs from Nathan/NTS or rallydesign. Note that rallydesign don't do 400lb 8" 1.9ID springs only 350lb. If you don't want to take a chance and want to be sure you get exactly what is recommended then go to Nathan and get a full setup from him. I'm skint so I took my chances. HTH. Chris  |
| Thread Tools | |
| Display Modes | |
