			 I need to order some nuts to temporarily fix my bottom ball joint and track rod ends.
			Any Ideas what the thread size is for these.. TT
	You only get a woosh with a dump valve Build Thread Man Cave Mantiques Cecil Street Auto Repairs Garage Carlisle Build Cost £4181.65 - Last - Wheel Cylinders  |
			 Im using the Transit ball joint and Escort mk2 rack and just measured the rack end thread;  M14 (diameter) x 2.0mm (thread.)
	Hope this helps ![]()  |
			 I presume you are talking about the nylocs or castle nuts that hold the track rods and the ball joints IN TO the bottom of the upright and the mushroom? I have a thread gauge and zeus book at the shop I'll check later, the tapers will be the same as the OE parts obviously how ever I can't say the same for the threads.
			Website http://www.talonmotorfabrication.co.uk/ Direct email phil@talonmotorfabrication.co.uk talonmotorfabrication@gmail.com Mobile office hours 07514098334 Last edited by Talonmotorsport : 13th May 2012 at 10:50 AM.  |
			 Steering rack M14 x 2mm
			Transit drag link M18 x 1.5mm and M12 x 1.5mm Maxi balljoint M12 x 1.25 Last edited by ozzy1 : 13th May 2012 at 11:20 AM.  |
			 do what i do just add a stack of washers to stop the nylon ring touching simples
| Thread Tools | |
| Display Modes | |
