Old 30th May 2012, 03:56 PM
MikeB MikeB is offline
Default Prop Shaft -Who to Make one
Has anyone got recommendations for companies to make a propshaft.
Standard type 9 to sierra diff, I don't have the original so no parts to use.
I'm near northampton.
M
Old 30th May 2012, 08:41 PM
matt2223 matt2223 is offline
you could try bailey morris they are located in st neots.
Old 30th May 2012, 08:54 PM
brainbug007's Avatar
have a search around here. I'm sure theres a company based around leeds somewhere that does good uprated ones for around 150 quid I think and will post it out to you.
Old 30th May 2012, 08:57 PM
I'm planning on using these guys:
http://www.baileymorris.co.uk/
I don't think they're the cheapest around, but they're not far from me.
The guys that run our engine test cells at work use them and recommended them to me.
Last year they quoted me £70+VAT to shorten one, and between £170 and £220 to make a new (MX5) one from scratch.
EDIT: You beat me to it mat2223!
Old 30th May 2012, 10:11 PM
martinl martinl is offline
the prop shaft company in leeds is dunning and fairbank they are located on cross green ind. est. near the m1, m621
www.dandfltd.co.uk/
Old 30th May 2012, 10:34 PM
got mine from Dunning and Fairbank £140.00 delivered
Old 31st May 2012, 07:31 PM
good quility and service and was also cheaper than the rest
mine had rebuilderble uj's with grease nipples that some wanted extra for.
had a chat with the guy there and he said unless you are going v6/v8 std duty is good for over 200bhp with a 4pot
Old 1st June 2012, 01:37 AM
Dunning and Fairbank -- based on what I've read on here you'll get a top quality item for the lowest price delivered to your door in 2 business days or so.
