Old 31st May 2012, 10:46 AM
FASTdan FASTdan is offline
Default danST Engineering
Hi All,
Some of you may know us from the locost builders forum among others. Just a quick post to make everyone aware of what we can offer:
Bike carb and throttle body manifolds. Fully TIG Welded aluminium construction built to suit whatever carbs/bodies you source. We also build these into complete packages consisting of carbs, manifold and fluoro lined fuel resistant silicone hoses (in a choice of colours).
Self weld Mild Steel Manifold kits. Again to suit whatever carbs you source. These kits consist of 8 tube sections cut and marked ready to weld to give your required engine/carb spacings and the 8mm flange plate to suit.
Pipercross PX500 and 600 Filter baseplates. Either blank or cut to suit a variety of bike carb applications. We also stock the filters.
Velocity stack kits to suit the popular bike throttle bodies.
A wide range of laser and water jet steel, aluminium and stainless steel manifold plates to suit most popular ford engines aswell as other manufacturers.
We also stock the popular DCOE/Jenvey type plates in 10mm aluminium.
Duratec Engine Mount kits designed to suit the MK Indy/Book Chassis.
Prop Shaft Catch Plates. Designed to mount in the tunnel of your Locost to capture the prop in the event of a failure.
The above is not exhaustive, other products and information can be seen on via the following links:
www.danstengineering.co.uk
http://stores.ebay.co.uk/DANST-Engineering
http://www.facebook.com/pages/Danst-...8944900?ref=ts
Any questions please email enquiries@danstengineering.co.uk.
*Edited to remove pics as they were far too big, please see above links.*
Thanks for looking.
Regards
Dan
danST Engineering
