Old 7th June 2012, 06:13 PM
misty misty is offline
Default no reverse
Hi All
bit of a problem tried to change gear today with the car not running and it would not get reverse gear,so took out the 3 bolts and removed the gear stick,had a look in and found something i new nothing about,did a little searching and found it was a saddle seen one on ebay but DO YOU THINK THIS IS PART OF THE PROBLEM OF THE REVERSE GEAR before i buy one .
Old 7th June 2012, 06:40 PM
What type of box ? On Type 9 there is a "rubber spring" that pushes down to select reverse.
Old 7th June 2012, 06:51 PM
dont see any rubber spring anywhere
Old 7th June 2012, 07:11 PM
PorkChop PorkChop is offline
Would it go into reverse OK before today?
Old 7th June 2012, 07:28 PM
when it was out on the floor yes it did
Old 8th June 2012, 07:50 AM
If all was well before dont worry about it. It wont have failed just by sitting there. You can get this situation on any box when the engine is not running, on a lot of boxes reverse is straight cut and dont like to mesh while not turning. If the prop is on try moving the vehicle slightly.
Old 8th June 2012, 10:51 AM
You should defiantly be able to put a type 9 into reverse with the vehicle stationary (without even using the clutch). Have you adjusted the throw on the gear selector, stopping it from sliding past the reverse detent?
If you have access, you can remove the cover plate behind the selector arm and check to see if the lever is moving correctly, then pop it back on.
The plastic saddle lasts for ages, unless its broken, I wouldn't bother replacing it.
Old 11th June 2012, 03:06 PM
ALL SORTED many thanks to all
Old 11th June 2012, 06:22 PM
For future reference the black thing under the E clip is the rubber spring thingy.
Old 11th June 2012, 06:55 PM
I had to replace mine recently, as I had a very sloppy gearstick ,
The saddle that fits under the gearstick are also available made from brass, but cost approx £27 ................. I fitted a plastic one at £6.50
Nice gearstick action now
