Old 9th June 2012, 03:00 PM
rpjg1975 rpjg1975 is offline
Default coilovers?
Hey guys. Found a set of coilovers which are cheap, but they are 320mm open and 260mm closed. Am I right in thinking they would be no good for our builds?
Not the end of the world if they are, just thought I'd ask the question as you never know if you don't ask
Russ
Old 10th June 2012, 01:30 AM
Too small ,320mm is 12.5" open.We require 13" open with 1" extension making it 14" open.
Old 10th June 2012, 09:03 AM
Cheers ozzy,
I thought as much but thought I'd check anyway. What a bugger!
Russ
Old 10th June 2012, 05:55 PM
dimlaz dimlaz is offline
this dimension is from center hole to center hole or total length?
Old 11th June 2012, 01:46 AM
Centre hole to centre hole .
