Old 17th June 2012, 06:58 PM
Matthew Matthew is offline
Question Front wing stay brake clearance
Hi
I'm in the middle of making the front wing stays to the book plans, and all seemed OK until I fitted the brake caliper. The stay runs right across the back of the caliper and I don't think there's enough clearance:
Front - Above - Wing stay clearance.JPGFront - Behind - Wing stay clearance.JPG
Has anyone else had the same problem or have I just made it wrong?
Matt
Old 17th June 2012, 08:23 PM
I had to notch my tube local to where the hose goes into the caliper. I didn't make mine, got em from Saturn Sports Cars. But I assume they follow the book?
Old 27th June 2012, 05:37 AM
Problem solved - I remade them with a kink in the rear support so the tube goes under the bulge in the caliper then up to the mounting point on the wing.
I think I may have found the cause too - it turns out I've the larger front disks (~280mm), not the ones I thought I had so the caliper position/size may be slightly different.
Matt
