Old 26th June 2012, 07:41 PM
Default P-Clips
I know this may sound a stupid question
If you fit a P-Clip within a tapped hole do you need a form of antiloose fastener such as a star washer etc... for it to be OK with Mr IVA.
Thanks Johno
Old 26th June 2012, 08:04 PM
Had a quick look around on locostbuilders and the general consensus seems to be they are ok as a few went through SVA with them..... or put it this way I have not heard one anyone failing for using them on P clips.
Old 26th June 2012, 09:17 PM
Phewwww,
Thanks Kev,
I know I have fitted roughly 80x5mm P-Clips for brake and wiring loom and probably 30x8mm P-Clips for the fuel lines.
Thanks Johno
