Old 9th July 2012, 07:51 PM
Default IVA Checklist
IVA Queries
Rear Registration Plate
2) The space must permit the mounting of a plate in a position as close to vertical as possible taking into account the shape of the bodywork.
Does anyone know if the angle of the rear tub is acceptable to pass the IVA, or will a wedge be required to make the number plate nearer to vertical?
Also, does anyone have any key points I should be checking?
Plastic Nut / Bolt Covers - Tick
GRP Cycle Wing Trim - Tick
Cycle Wing Stay Brackets - Tick
Bonnet Edge Trim - Tick
Aeroscreen Trim - Tick (Does the lower return require trim as well)
Rear Tub Trim - Tick
Inner Edges of Scuttle Return - Tick
Inner Edge of Nosecone - Tick
Steering rack / Top Wishbone Ball Joint Nuts - Tick
Steering Rack Extension Rubber Gland Cover - Tick
Flexi Brake Hose onto front caliper - Tick
Trim to underside of Headlight Mounts - Tick
Fog Light Vertical - Tick
Exhaust Silencer - Tick
Correct E Marking on Lights UPDATE (Ozzy1)
Seatbelt Boss Gusset UPDATE (Deezee)
Thread sticking out of nylocs UPDATE (Deezee)
Roll bar main bolts need to have strength rating on them UPDATE (Deezee)
Any help appreciated to make sure its all covered.
