Old 18th July 2012, 08:01 PM
trick-kit trick-kit is offline
Default Clear out of the workshop
Having a bit of a sort out of the worshop today, as a couple of new projects are about to start, has unearthed a few Roadster parts that I thought it best to offer up to you guys. Other wise they'll sit under the bench for god knows how long.
All parts are new and of top quality, as anyone who used to purchased from me during my 3GE Components days will testify. Anyway here are the parts.
1. CP3/4 assembly package, this is the shock/roll bar towers for both sides, complete, as they are to my latest self jigging design which locates everything including the shock mounts £20 posted SOLD TO JOELOVE
2. RU7 Pair of Rear up right plates in 10mm mild steel £15 posted
3. RU8 Pair of Rear Upright Plates in 10mm mild steel £15 posted
4. Steering Rack Mount kit, consisting of CP19, CP20 & CP21 £10 posted
5. Small Brackets Set, consisting of CP1, CP2, CP9, CP22, CP23, CP24 & CP25 of the right quantites for a chassis. £15 posted
6. CP11 Pair of plates in 1.5mm rather than the 1mm the book recommends. £8 posted
7. CP10 Pair of chassis plates in 5mm (the correct length and with markings to show correct orientation) £10 posted (2 sets available)
8. CP15 Pair of Steering column plates £7 posted
9. CP14 Hand brake cable stop, has cut out for easy cable fitting £4 posted
10. CP18 Seat belt brackets, set of 4 £8 posted
11. CP16 plates, in 1.5mm instead of 1mm, £7.50 posted
12. CP17 Footwell plate, again in 1.5mm insted of 1mm £7.50 posted
13. Unlucky for some, a few bushes, consists of a pair of bushes and a stainless steel crush tube £4 each (6 available)
Some of the above may be helpful for someone, I can always be contacted via PM on here or at john@trick-kit.co.uk
TK
Innovation not Imitation!
Old 18th July 2012, 10:46 PM
Joelove's Avatar
Joelove Joelove is offline
Message sent
Old 20th July 2012, 09:04 AM
And found these I think that's it for Roadster related stuff now.
14. VW Polo 1L Radiators ('83-'90 models) £22 Posted - I've got 3 of these, so first come first served. ALL SOLD
TK
Old 20th July 2012, 09:28 AM
PM sent
Chris
Old 20th July 2012, 10:06 AM
Big Vern Big Vern is offline
I have sent you a PM
Old 20th July 2012, 03:49 PM
Jimmyd Jimmyd is offline
And I'll have a rad if one left
J
Old 20th July 2012, 09:19 PM
All gone, sorry guys!
TK
