Old 8th August 2012, 05:25 PM
Default Diff ratio
My car can pootle round town at 30mph in 5th and i often tend to pull away in second as it just means 1 less gear change. I cant find any identifying marks on the diff to tell the ratio. Based on the above should i assume its a very low ratio diff and think about changing it or is this quite normal ? I'm running 2.0 Pinto with type 9.
Old 8th August 2012, 07:51 PM
No, you should jack up your car and count the number of rotations of the wheel to that of the propshaft. Or take the rear cover off the diff and look at the ratio stamped into the wheel. Otherwise any advice it going to be total guess work.
Old 8th August 2012, 07:52 PM
snapper snapper is offline
The type 9 whilst better ratios than an MT75 is still not ideal
1st to low as is second 5th to long
The ideal is a V6 box with a long first and a 3.9 diff
Tyres add to the ratio mix but in essence you want to get 1st and 4th close enough to give 40+ mph in 1st and about 125 in 4th
5th can be for long cruises
Extra rev range for the engine helps close the gap
Old 8th August 2012, 08:27 PM
You can always play with a gear calculator first to see whats going on. Better to spend some time on research and get it right before a spanner attack. You can see what snapper was on about in the type 9 chart.
http://www.apexgarage.com/tech/gear_ratios.shtml
http://www.type9gearbox.co.uk/type-9-production.html
Old 8th August 2012, 11:51 PM
125 in 4th yeah good luck. anything less than 200bhp in a 7 and you want 4th geared for 90-95 and 5 geard for about 125-130. look at the ratios in a caterham for reference, their ratios are about as spot on as it gets for a 7. aero is a huge limiting factor on a 7. mine is a fire breathing 2.0 turbo running over 200bhp and it will only do 145 flat out which in a 7 is bloomin quick and a total assault on your body and senses, the other issue is that around 125ish the steering gets very light an twitchy on the mass majority of 7's
Old 8th August 2012, 11:53 PM
oh and to answer the initial question. forget the diff. take the box to bgh and get them to rebuild it with their uprated gear set which has better ratios.
Old 9th August 2012, 10:31 AM
Woooooooo chaps, he is just pointing out the fact that he finds 1st gear a bit on the short side. I dont suppose for one minute he cares if it does 145 mph or not. The first suggestion about the v6 box is valid so I put the numbers in the gear calc and it makes about 5mph difference, its a start, Better diff ratio would also help even if the engine wont pull it to max revs in top. loads of options really. It sounds to me like he would prefer it to be purring along at 2000rpm at about 70 and thats a bit of me
Another poss way of calculating diff ratio http://www.bimmerhaus.com/tech/diff.html
Old 9th August 2012, 12:32 PM
Forget that 7's are all about instant acceleration as I have discovered driving mine. Ideally you want 3rd and 4th sitting right in the power band
Old 16th August 2012, 11:00 AM
Ive found out from the last owner it's a 3.62 ratio diff. Is this fairly average ?
Old 16th August 2012, 09:17 PM
Yep, it's the "bog standard Sierra diff" ratio. I have the same. Some really weak ones had ~3.3, some stronger engines have 3.92, but 3.62 is the most common.
