Old 13th August 2012, 01:32 PM
MikeB MikeB is offline
Default CVH Clutch plate wanted
I popped the clutch plate out while I had the engine out.
It seems to have less than a mm on the grooves.
The CVH will only be in for 2k miles max though so don't know whether to change it, dont' really want to pay £60 for a new one.
If anyone has a spare one with more meat on it....
I'm also going to chop the sump, any tips for replacing the sump plug, I don't have a tap big enough for the current size?
Mike
Old 14th August 2012, 03:04 AM
http://www.ebay.co.uk/itm/Ford-Sierra-1-8-CVH-Flywheel-And-Clutch-/140821872844?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item20c9a340cc
Old 14th August 2012, 06:42 AM
Use a smaller nut and bolt through the sump wall lower down and put a copper washer on the outside to seal it,if you look at most tin sump pans that is basically what they use.
