Old 21st August 2012, 05:53 PM
Default Nifty Bonnet scoop
http://www.ebay.co.uk/itm/Dax-Rush-B...item20b88ffa05
Dax rush bonnet scoop. I thought its quite a neat thing if you need to come out of the bonnet line.
bob
Old 21st August 2012, 06:53 PM
I quite like that Bob, and they're not far from me either.
Old 21st August 2012, 07:33 PM
The guys at Dax are only 30-45 mins from me down the 414 but at nearly £100 for a scoop call me picky but I'd want a bit more bonnet for that kind of dough.
Old 21st August 2012, 07:50 PM
Depends on how you look at it. If you already have a bonnet on the car and an engine swap means your outside the bonnet line this is a cheap quick option. They can also colour match it so if you value your time I think its fair, it looks right as well. Just my worthless humble opinion
Old 21st August 2012, 08:57 PM
Don't get me wrong if you've got the budget to spend DAX body work is near flawless in it's finish. I did think about 'borrowing' their design to fit to my bonnet but I don't think they would be to happy, besides I've met them and they are bigger than me.
Old 22nd August 2012, 12:47 PM
Everyones opinion on here is humble, just some are more humble than others
Old 22nd August 2012, 01:53 PM
MikeB MikeB is offline
A cheaper option not sure on the sizes.
http://www.agmsportscars.co.uk/agm_s...cars_2_016.htm
Old 22nd August 2012, 07:05 PM
I said I liked it and was more just expressing my surprise that a supplier is actually close to me, I'm probably 18 months to 2 years away from actually needing bodywork so wont be sending an order off just yet
Its always good to see different options even if its just for research and comparison.
