Old 17th September 2012, 11:30 PM
DaveyB DaveyB is offline
Default Pinto position
Has any one any actual measurements for the engine mounts position for a pinto engine or is best waiting and trial fitting the engine ?
DaveyB
Old 18th September 2012, 07:27 AM
I'm waiting to possition it in and then line up the mounts to suit
Old 18th September 2012, 08:53 AM
mgglep's Avatar
mgglep mgglep is offline
the engine is governed by the gearbox mount i fitted my engine so it was level as it would be in the car i bolted the gearbox mount in then blocked the engine up then made my mounts to suit
My Build pics
Old 18th September 2012, 03:29 PM
if your fitting a type9 box then its dependent on the gearstick and reversing light switch clearence in trans tunnel tubes and clutch arm clearence
you do get the motor quiet far back
Old 18th September 2012, 06:05 PM
Its always worth asking the question as others have tripped up on the way. Series landy [ steve] had issues with his drivers side mount and steering shaft configuration so it might be worth a dig about his build thread before you get the mig out.
Old 18th September 2012, 08:25 PM
As bob says I had a few problems with the pinto.
1st I struggled to get the g/box far enough back. The clutch fork was hard up against the chassis rails, and in 1st gear the leaver hit the bar in front. So I moved the gear lever back with a remote selector.
The engine mounts are another story. I used the near side one as per the book with cast strut and rubber mount.
On the o/side I originally went book spec but the steering shaft hit the bolt on the top of the engine rubber.
I fabbed up a new strut and removed the book 3mm plate mount and welded in a flat plate to the chassis rails.
I would say that I wouldn't weld anything Untill you trial fit the engine.
There are some pics of my mounts in my sig
Old 18th September 2012, 09:10 PM
mgglep's Avatar
I didn't use the straight mounts I made angled mounts so I had plenty of clearance for the steering shaft
My Build pics
Old 18th September 2012, 09:12 PM
mgglep's Avatar
Found a pic
http://m.flickr.com/#/photos/67605695@N04/6153645019/
My Build pics
Old 18th September 2012, 09:57 PM
Oh wow cheers guys thanks for all your thoughts on this subject your help has been spot on thanks again.
DaveyB
Old 22nd September 2012, 11:14 PM
I recently asked about the vauxhall red top engine being a suitable choice for fitment, and got great help thanks for that, they look and seem a good choice. Then I get talking to a neighbour who tells me he has an old pinto in his garage he does not want, and I think maybe this would be an easier choice at the moment if I did go for this engine do I still need some form of receipt for iva proof of purchase /acquirement etc. he said it was in a cortina originally and has be ported amongst other things would this be a good motor to go for.
Thanks
DaveyB
