Old 22nd September 2012, 05:15 PM
Default Garage Type Tools & Roadster Parts for Sale
I have the following domestic garage items for sale that we either never use or will not be required in our new premises: I have not worked out the prices yet, but will post here before it goes on Ebay. Items will need to be collected from Plymouth, Devon unless small enough to post:
Ford Type 9 V6 Steel Bellhousing (Capri 280 i think) (Sold)
Round Rear / Fog & Reversing Lamp Pods (Brand New) (Listed on ebay)
Electric Cooling Fan Wiring Kit
Clarke Little Devil Gas Workshop Heater 35.000 btu/hr 10.8 kw (Large Full Handygas Cylinder also available as local supplier not trading) (Sold)
Powrmatic Gas Warm Air Heater +Timer control (Sold)
Turbo Weld 8 Stick Welder (Single Phase or 3 Phase)
Guysons 25 Kg Grade 13 Blast Shot (2 x 25kg brand new)
4 x 25 KG Medium Glass Blast Shot
Clark Blast Cabinet full of fine shot, + gun + light + gloves
Small Rockworth 240 V AC Generator with 12 V DC output
Astra No 3 Small Electric Bench Drill
Performance NLH50LCAL 50 L 8 Bar Compressor 1500 w
Axminster AW30HP 3hp Direct Driven Air Compressor
Clark High Lift Clark Pump Pallet Truck
1 Ton Hand Stacker 1.6 m High Lift Lever Opertated Pallet Truck (Sold)
Clarke 1/2 Tonne Chain Lift (Brand new boxed and sealed)
Small Fly (Sold)
Arbor Press
Possibly for sale a Clarke Gas / No Gas MIG 105 EN Turbo Welder as new, with regulator / 2 nr wire spools or different sizes, spare tips, etc, + large refillable gas bottle but may keep as its a handy pit of kit as does not require the large gas bottles
Photos of everthing will be on the ebay listings, search for seller: spikehaas
Old 23rd September 2012, 10:27 AM
Hi, have you got a few more details on the Clark Blast Cabinet and chain lift?
Old 23rd September 2012, 01:55 PM
The caninet is identical to this one, apart from its full of fine grit and been used a few times.
http://www.machinemart.co.uk/shop/pr...=1&TC=SRC-shot blast
I will have to check the number on the box of the chain lift, will add as soon as I can, but its a standard clark model
Old 23rd September 2012, 11:01 PM
I think that would be fine for my bits, I downloaded the manual but I cant find any details on the weight of it though as I was trying to work out the courier costs.
How much are you looking for? and is there any chance of weighing it? It would probably have to be shipped without the media.
Old 24th September 2012, 10:49 AM
any info on the fan wiring kit
is it just relay and wires or does it have a temp switch/sensor?
Old 24th September 2012, 06:05 PM
If you can PM your email address I can send photos of it
