Old 25th September 2012, 09:43 AM
Ricky Ricky is offline
Question stainless steel chassis
Hi everyone I just want to find out something say for example I could get all the steel for the chassis in stainless steel at a better price as mild steel would it be a good idea to do it ? Is it stronger ? Is it perhaps lighter then mild steel ? Would it be a good idea or not really ? Thanks
Old 25th September 2012, 11:05 AM
vmax1974's Avatar
vmax1974 vmax1974 is offline
It would all depend on what grade of stainless you use general opinion is that stainless is too brittle and could suffer cracking
Someone with better knowledge will be along soon I am sure
Old 25th September 2012, 11:18 AM
I'm pretty certain that stainless steel is heavier (all grades ) remember the delorean ? That had a stainless body and was well heavy.
Old 25th September 2012, 11:19 AM
Stainless is fine for bits of bodywork but is a real pain to work with using DIY tools and techniques (even drilling it is a nightmare) which is why most tend to stick with plain steel or aluminium for things like floor sections. As Vmax says stainless can be brittle when used structurally in a chassis. Robin Hood made a stainless chassis at one time and switched back to plain steel and I know that the 750 Motor Club don't like 7esq cars with stainless chassis in their racing categories.
Old 25th September 2012, 01:32 PM
Originally Posted by Not Anumber View Post
If you want to build a solid chassis that will be useable in 20 or 30 years make it out of steel and get it shotblasted and galvanised before painting.
Please don't recommend galvanising box section. As its hot dipped at 500 degrees you need to drill a couple of holes in every tube to vent any moisture and air. So unless people want a hole ridden chassis that's probably been filled with zinc, I'd leave the idea well alone.
Old 25th September 2012, 01:48 PM
Thanks guys for your help I was just not sure if it was a good idea or not so ya mild steel is fine once again thanks a lot for the info guys
Old 25th September 2012, 02:49 PM
dont galv paint will not stick to it well
Old 25th September 2012, 04:07 PM
http://www.drhess.net/papillon.htm
This is the website of a guy building a stainless steel Locost in the USA.
Old 25th September 2012, 05:53 PM
My mate bought one for his kid, thats got a stainless chassis.
http://www.haynes.co.uk/forums/showthread.php?t=8342
Old 25th September 2012, 09:22 PM
snapper snapper is offline
This guy built a whole car out of stainless
Chassis the lot
http://www.paulgooderham.co.uk/
