Old 9th October 2012, 10:46 PM
DaveyB DaveyB is offline
Default Build progress
How far can I progress my build before I need to fit engine and gear box?
DaveyB
Old 10th October 2012, 02:09 AM
Up to the point you want to paint the chassis as u will need to put the engine and gearbox mounts in. You could grind some off to weld the mounts on after if you wanted to though. My intent is to build it then strip and powdercoat then final build up.
Old 10th October 2012, 07:49 AM
Put it in to get it sorted, then pull it out till the point when your finalising things like water systems, engine electrics and fueling.
Mine so far has not come back out as I suffered a hernia precluding me from heavy work. Then the garage got too untidy to move
Back to doing stuff very sooon.
Old 10th October 2012, 11:00 PM
Thanks for the reply big help,
DaveyB
