Old 13th October 2012, 12:43 AM
Old Jag Guy's Avatar
Old Jag Guy Old Jag Guy is offline
Default Tubing Size??
Well, since I have the total first section(BR) almost complete , I guess I should ask"What is the max. horse power recommended for 25x25x1.5 tubing"? Thanks, Don
Miss you Doug and Charlie!!
Old 13th October 2012, 09:27 AM
I think the general concensus on this is the car will break traction long before hp or torque will have any effect on the chassis, if you are going beserk on the hp front you can go 2mm wall and add strengthening plates.I did read on a thread that 250hp was the limit on a stock chassis but that is just a pointer not a calculated max.
Old 13th October 2012, 01:29 PM
Good afternoon, and thank you Bob and TMS . After I asked the question, I kind of new the answer. I should have known it would be quite safe, as there are a lot of the "standard" chassis out there. I guess that's what happens when you have been away from "true sports cars" for many years! I didn't do any of the chassis work on it, but I remember that we rebuilt a Lotus 11 back in the early '70s, and raced it. That was a blast! Again, thank you gentlemen.....I think I was doubting myself more than the car...............Don
Old 13th October 2012, 06:14 PM
Replace the doubled up 25x25 sections of the rear seat/diff area with 25x50 section and possibly brace the diff mountings to add strength,this area is loaded most and likekely to twist given a bit of spirited driving.IMHO
Old 30th October 2012, 08:18 PM
jay395 jay395 is offline
The back end will break away even with 90-100hp even in the dry if you try to push the laws of physics, tyres that are too wide for the weight of car and running cold will not help this either. A Caterham runs 185/50/13 wheels and tyres for a car that weights around 600kg where as most roadsters run 195/50/15's?
I understand people wanting to run 150hp plus to have pocket money fun for super car thrills but how often will you be able to use it on the road, great fun on a track where you can open it up on the straights but when your being held up by the 4 cars and a bus?
If you want to improve the chassis in a quest for taking the power or better handling upping the chassis tubing to 2mm will add weight this will warm the tyres up more which is not a bad thing but only add marginal stiffness. If you look at the intended construction of a basic chassis it is ment to have sheet material bonded to the sides to act as added diagonal stiffness between the chassis rails, if you use GRP sides you rob the chassis of this benefit. Another thing to consider about the use of sheet material is the floor, if this is made in two coffin shapes they are free to move independent of each other. A floor that is one piece with the a cut out for the gearbox will act as the only diagonal between the near side rear corner and the off side front footwell.
Some well thought out tubular bracing added to a 1.6mm walled chassis will be lighter and just as stiff as a 2mm basic chassis, being lighter adds to the power to weight ratio and being stiffer than standard will add to any improvements made to the suspension. The only way to make the chassis stronger beyond the basic design is to add a full rollcage to bridge the large space that is the cockpit area.
i can get loads of the 25x25x2 mm box but not as easy for the 1.6 down here in sunny cornwall, i would have to order it all, would the extra 0.4mm really add much to the overall weight?
Old 31st October 2012, 04:58 PM
It's very easy to calculate: a meter of 25x25x1.6 weighs:
25 mm ^2 - (25 mm - 2 * 1.6 mm)^2 * 1000 mm * 7.8 g/cm^3 / 1000 = 1168 g
For 2 mm thickness this is:
(25^2 - (25 - 2 * 2)^2) * 1000 * 7.8 / 1000 = 1435.2 g
Which is a 22% increase in weight. If we use 42 m of 25x25 and 14 m of 20x20, the increase in chassis' weight will be around 14 kg. Whereas the increase in bend stiffness of these tubes will be around 15% or so.
A much better increase in chassis torsional rigidity can be achieved by the "Aussie mods": triangulating the front frame, bridging the chassis under the gearbox where the bottom rail is cut out, triangulating corners of the engine bay.
Old 31st October 2012, 06:50 PM
That all ways seemed silly to me cutting out part of a perfectly strong chassis design, would it not make more sense to make the chassis 50-75mm taller and leave it intact?
The problem with that is that you are then raising the engine and drive train by 50mm, and as that is the main weight in the car that will be bad for handling.
I want to have a completely flat underside to my car for aerodynamics as well as stiffness, but it's putting my tall engine 80mm out of the top of the bonnet. That is just from the gearbox which sticks out further than the sump at the moment, and will even further when i've fitted the dry sump.
Old 31st October 2012, 07:46 PM
Davey's Avatar
Davey Davey is offline
In response to the original question it depends on whether you mean "how many BHP will make it undriveable?" or "how many BHP will break it?". Sadly the answer to both is "it depends". Undriveable is an unmeasurable concept, F1 cars are pushing 800ish BHP through rear wheels in a 600 KG chassis at 200 MPH but few of we mere mortals would be able to drive it at all.
As for how much power it will take to break it, again "it depends". How heavy will it be and rather than BHP look at the torque the chassis has to contend with. If there's lots of torque ( think of Robo's V8 beast or my own V6 Cosworth job, not massive power but serious torque) and you are using soft sticky tyres and driving it in anger on track then there is a good chance of something breaking, probably the rear diff/suspension area for a guess.
Just my humble opinion, D.
Old 31st October 2012, 09:15 PM
Originally Posted by beardydave View Post
I want to have a completely flat underside to my car for aerodynamics as well as stiffness, but it's putting my tall engine 80mm out of the top of the bonnet. .
80mm what is it a cummins truck engine?
Old 31st October 2012, 10:06 PM
I'd be interested in seeing the triangulation options/pictures, has anyone done this? This might be something I should also consider.
