Old 22nd October 2012, 07:53 PM
Default Dashboard
Lo all,
Well I've started work on my dash and scuttle fitting and have a couple of questions.
1, Do you have to fit panels under the scuttle area to seal off access to the electrics?
2, If I pad my dashboard do I have to have a 19mm radius on the bottom of the dash. I plan to have a 90 degree return on the bottom of the dash which will be padded so not sure?
I plan to fit my dash behind the flange on the scuttle and fix through with powder coated dome bolts (coloured black of course) and have riv nuts inserted into the ally dash.
Any advice greatfully welcome.......
