Old 23rd October 2012, 08:22 PM
will_08 will_08 is offline
Default Steering extension tube?
Hey guys
What tube have people used to extend the steering column?
Ive searched previous posts and found answers from 16mm - 1.6mm wall
To 25mm - 3mm wall!?!?
Im happier going heavier to be fair, but will the 25mm tube leave plenty of clearance between the uprights?
Im building a book spec car btw
Cheers Will
Old 24th October 2012, 01:46 PM
25 mm fits, the clearance is minimal (3-5 mm).
Old 24th October 2012, 04:53 PM
cool that's what my local place has anyway, is a meter enough? or do you need more?
Cheers Will
Old 25th October 2012, 04:46 AM
Put the lower column in place in the steering rack and measure approx 50mm past the upright. This will give u more than enough to fit into the extension tube and will give u the maximum clearance of the upright.
A metre is more than enough tubing.
Old 25th October 2012, 10:20 AM
Cheers Oz
Old 25th October 2012, 03:04 PM
jps jps is offline
I'm really struggling with this. Book spec car - but the steering column and the Pinto engine mount both want to occupy the same space at the same time... There is another thread about this - but no solution that I could see - other than reroute the steering or modify the engine mounts - neither of which are mentioned in the Book..??
Old 26th October 2012, 01:06 PM
Steve " serieslandy " covered this and had to remake the engine mount. Its all in his thread.
Old 26th October 2012, 04:26 PM
i used 25mm seamless thick wall i think. i have a massive length still left
Old 26th October 2012, 09:09 PM
All covered here I was building to the book, now it's slightly not to book spec.
I also have a different mount for the column bearing, it lifted the column a bit but still didn't have enough clearance.
If you need any photos or anything pm me, as it was only luck I looked at the forum tonight
Old 27th October 2012, 11:28 AM
jps jps is offline
Will do Steve. Sorry, wasn't ignoring your solution on the other thread, although it seems your point on the other thread might be right, ie the spec just doesn't work as its written in the book....
