Old 9th November 2012, 07:41 PM
steady eddie steady eddie is offline
Cool Bike Engine Reverse Wiring
Hi everyone
I'm going to put a bike engine in my roadster (eventually) the chassis is all done, front suspension made, everything painted and going well.
I like to plan ahead so the starter motor route for a reverse will be the road to go down. So to try and make life a little easier does anyone have a wiring diagram?
Half a mild in the Rat and Vomit to the winner:
Old 9th November 2012, 09:07 PM
No wiring diagram sorry,just make sure it only works in neutral and with the handbrake off only.
Old 11th November 2012, 05:34 PM
Default reverse wiring
thanks for the advice, i appreciate any advice, but how would i do
what you suggest, it still leaves me with a problem, I'll keep looking
on the forums.....cheers Eddie
Old 11th November 2012, 06:07 PM
These ready made jobs seem good value.http://www.blitzworld.co.uk/joyrider...-box-i421.html. I dont think you would get much change from that if you start trying to mount starters to mesh into ring gears on the prop. It all has to be supported on brackets and bearings which is a bit messy. 100mph in reverse
Edit Wheres that beer
Old 11th November 2012, 08:49 PM
Someone on the forum has done it with a ring gear from MK if I remember correctly,and again if memory serves me right it was a Seat starter motor.
No electrician but you can use the neutral switch in the bike box to feed a relay to inhibit it as per previous post.
Some kind forum member will remember and post a link.
Old 12th November 2012, 09:03 AM
loony's Avatar
loony loony is offline
OK - I'm "building" BEC, so I'm trying to prepare for unexpected problems
My Roadster will have electric reverse with VAG starter motor. It's because VAG starters turn counterclockwise... You can use most of them, but they have different sizes.
The gear you need is 12DP - the bigger you fit the easier/slower will go
Very helpful pictures: http://www.locostbuilders.co.uk/photos.php?action=gal&user=40inches&folder=Electri c%20reverse
As for electric diagram... I plan to connect relay(NO) feed to neutral switch, and second relay(NC) feed to brake light switch - in this way I can reverse by brake pedal.
But this is only my theory
Lucas
ZX9R BEC Haynes Roadster - build cost so far: £1125
My build thread
"Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe
Old 12th November 2012, 02:36 PM
What happens when you're rolling back and need to stop? Press the pedal until it overpowers the reverse motor?
Old 12th November 2012, 02:45 PM
loony's Avatar
First relay NO (neutral switch) and second NC (brake light switch) are in series.
When I press the brake pedal, brake light feed will disconnect reverse motor, and brakes stop the car...
Of course there will be manual "reverse switch" to activate system.
"Fast" diagram...
Like I said - it's just theory So any suggestions welcome.
Lucas
My build thread
Old 12th November 2012, 10:07 PM
NO and NC are normally open and normally closed,might make it easier to understand.
My two pennies worth,neutral switch in the g/box,handbrake switch,and clutch switch will make sure it only works in neutral and hand brake off.
Old 13th November 2012, 08:46 AM
The only thing wrong with this starter motor reverse thing is there is no speed control. Cant help thinking that it would be a complete ballache trying to reverse that into a tight parking space that needs a shunt or two. There wont be any feel to it , on/off thats it and if you ended up with a 3.1 diff with that size ring gear on the prop your reverse is going to be very rapid Just thoughts
Just put that lot into a speed calc. and thats 32.8 mph reverse gear on a button
