Old 26th November 2012, 09:29 PM
steady eddie steady eddie is offline
Exclamation roll bar
Hi 2 all
I have a query regarding the roll bar bracing bars, I was wondering if
there is an IVA requirement to have these, personally I would like to
leave them off! other builders seem to do without, so if anyone
can point me in the right direction............
may the force be with us
Old 26th November 2012, 10:02 PM
Depends if you have your seat belts mounted to the roll bar or not.
If you mount your seat belts to the horizontal bar at the bottom of the roll bar then you need to have either front or rear roll bar stays. How ever if your seat belts are mounted to some where like SB2 , RS4+5 ect then you don't need front or rear stays.
Old 26th November 2012, 10:25 PM
I am not using rear stays on my build but the bolts have been upgraded to m10 and I also had it welded by a very good offshore welding company. Not sure who it was but someone has passed Iva witho it these. Nathan knows who it is.
Old 27th November 2012, 07:42 AM
mgglep's Avatar
mgglep mgglep is offline
One thing to consider other than iva is if god forbid you roll it I personally think from a safety point of view the more bracing the better as the roll really is the only thing stopping your head hitting the floor
My Build pics
Old 27th November 2012, 06:51 PM
shh120m's Avatar
shh120m shh120m is offline
Mark from billingham passes without rear stays, his harnesses are mounted on the roll bar cross member. I have seen loads of mnr's on the road the same. Mounting to the seat back rail is a pita as its quite low, but a lot of manufacturers do, mk for one. Better to mount on the rollbar to get a bit of height behind the shoulders, harnesses should never be mounted below shoulder height. At the end of the day, its your choice, some iva testers may not like it, i dont know. Better to be on the safe side, or even better to keep it shiny side up
Old 27th November 2012, 08:23 PM
Its a valid point really. without the bracing the roll bar cant be as effective. Safety has to come first. With the single roll bar a line needs to be drawn from the top of it down to the nose cone and its only below that line theres any protection. Which is why I want one like this http://img826.imageshack.us/img826/8...0911205527.jpg
Old 29th November 2012, 08:41 AM
I don't believe it's so, take a look here, for example:
http://www.securon.co.uk/fitting/ext...essfitting.htm
FIA requires, conversely, that harnesses are never mounted above shoulder height.
Old 29th November 2012, 08:46 AM
shh120m's Avatar
i stand corrected, i hadnt seen this. Il look tonight but i was sure the iva cotradicted that. If im wrong il keep my mouth shut, not right about much these days.
Old 29th November 2012, 08:51 AM
shh120m's Avatar
http://daliracing.com/v666-5/downloa...eplacement.pdf
. Either your link is way out of date or manufacturer is not bothered what happens to the body during an accident. Im sure iv also seen some proper reseach into this, il keep looking
Old 29th November 2012, 08:52 AM
Davey's Avatar
Davey Davey is offline
Best not to confuse FIA requirements with IVA requirements, they frequently contradict.
D.
