![]() "Hubcentric", that's the word! Thanks, I'm learning almost every day out here
![]() Yes, they are very expensive, and sometimes, it is cheaper to find other wheels with the right ET...
![]() Well, these wheel were £190 for a brand new set of 4 so even if I buy hubs I'll still have saved a bit. I can atleast spacer the wheels to be flush with the rear arches.
Stanced! ![]() |
![]() I only went with ET15 so the rears filled the arches but then I decided it wouldn't hurt to go ET 15 on the front for clearance just incase. Can you not send the wheels back and have them send you a different ET set. I tried spacers with the original mx5 wheels and it just made me feel uneasy when fitted. edit: ET15 on the front with 13" wheels just about allowed use of full escort rack steering lock btw.
![]() what width "13s are you running?
![]() I'l sourced some good quality spacer which if the rear arch drawins are accurate should result a good looking fitment.
13x7 Rosco although a 13x8 would likely be possible on the rear if desired. |
![]() OUT
![]() I've gotten use to my car and it's performance so time for a change, I finally took the plunge and removed the engine while the sun was still out! And I finally own an engine crane! ![]() This 1.6 engine did a full 360 miles in my car, I'm so glad I didn't spend loads of money on it. ![]() |
![]() What are have you done to the 1800?
