Old 14th September 2015, 03:25 PM
I just carefully tapped for M6 and used a rubber washer to seal against a socket cap screw. Just nipped up the socket screws not too tight. I have some 4mm Ali and I'll rivet a piece on with some closed rivets and RTV if they strip and tap that instead.
Saying that I'm not convinced now I really need them, As the water flows down and then up in that orientation, as long as you have a header above the radiator it should naturally fill up.
Ahh I see, smart. I was looking at using some rubber rivet (well) nuts, I thought that's how you had done it. I'll try it without and see how I get on. Cheers
