Old 18th October 2015, 10:03 PM
Originally Posted by norton View Post
The water pump inlet is kinda awkward though. I've been looking for an oem pump inlet that faces directly forward not to the passenger side like the original.
I've seen some fit the original back to front which could help but I may end up making one.
I've had the same thoughts, I came up with rotating the inlet 180˚, core plugging the heater matrix feed, cutting off the 90˚ bend and having the straight bit left behind machined to fit a 32mm hose. If you make one let me know so you can make me one too. The small 8mm outlet can be cut and redirected using standard plumbing items or just blanked off.
