Old 15th July 2016, 09:03 AM
Picture is not helpful,I would think there is some mechanical adjustment on pad rod for h/brake as you would loose the hand brake when the pads wear.
Try slackening cable off and if the is an adjuster screw it up tight to lock wheel and then back it off one turn to allow for heat.
Good luck.
